What is the optimal temperature for i5-3570?
BIOS shows temperature as 52-56 deg C for this CPU and for Mother board it is only 35-38 deg C.
Intel does not provide temperature ranges for each processor, as it varies by processor.
However, temperature ranges could go from 50C to 80C.
The following link will provide more information about the Processor operation temperature http://www.intel.com/support/processors/sb/CS-033342.htm Processors — Processor operation temperature FAQ
regards,
maintain the cpu temp below 70 c at all costs .since the mobo temp is already low it should not be a problem. if u r worried install a good cooler to lower the temperature. simple as that...
regards,
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
