Processors
15890 Discussions
i5 8400 overheating
R101
hi, I am using a cooler master hyper H401R, I just bot it.
I have checked everything 2 times, everything is fine.
in-game it starts with 80.c and goes to 100.c within 15-20 minutes
and then stays at 100.c at the time that's why I get less fps in-game
is there any fix for this overheating.
AlHill
Inadequate ventilation.
Incorrectly installed cooler.
Incorrectly applied thermal paste.
The processor was working ok before you purchased this new cooler?  Return the cooler.
Doc
n_scott_pearson
Also possible that fan speed controller is not configured properly to react to these high temperatures.
R101
ok so I have done everything again and now I'm getting the high temperature of 70c
and normal temp of 50c
is that ok for the health of the CPU the highest is 75c
AlHill
Yes, sounds like all is normal now.
n_scott_pearson
Yup, the processor is happy at 75c. 50 is a tad high for idle temperature, but some solutions shut off the fan down in this temperature range and thus it doesn't go lower.
