I have heard that Windows 11 systems with hybrid-architecture CPUs utilizing performance and efficiency cores (P-Cores/E-Cores), such as the 12th Gen Intel® Core™ Alder Lake or newer, can lead to audio dropouts and reduced performance.
Is there any resolution? Is there any assistance with this?
I have an i9-12900 with Windows 11, and I have some of the best sound on my PC ever, with local files and online streaming.
However, I do not have an HP machine.
Just saying....
Hello Stuominous,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® UHD Graphics 770.
1. When did the issue start?
2. Have you checked this issue with HP?
3. Have you made any BIOS changes?
4. What is the graphics driver version?
Deivid A.
1. Started on Day 1
2. Yes, I have checked with HP - no resolution. Any assistance is a "Premier Assistance" option.
3. No BIOS changes
4. Version 31.0.101.4091
Hello Stuominous,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello Stuominous,
Thanks for the information. Before we continue further, I would like to confirm the following:
1. Is the issue present when using the laptop-embedded speakers, headphones, TV, or external speakers?
2. Do you see any errors in the device manager (code 10, code 43)?
3. Have you performed all the operating system updates, even the optional ones?
Deivid A.
1: The dropouts happen ONLY with my Steinberg URmkII Audio Interface. USB headphones, 3.5mm jack headphones, and combo headphones/mic all work fine with zero dropout. Unfortunately, my speakers are ran through the Steinberg URmkII Audio Interface.
2. No error messages
3. All available updates are routinely checked and applied. Currently up to date.
I have learned that there is an issue with the driver and compatibility of my Audio Interface and the Win11/i7-12700. I'm beginning to believe that the issue is not with the i7-12700 at all, but with the device or driver itself. There was a recent Yamaha/Steinberg driver update that did not repair the issue.
I will need to contact Steinberg for more assistance. Thank you.
Hello Stuominous,
Thanks for all the information provided. As you mentioned, if the issue is only present with the Steinberg URmkII Audio Interface and your system is fully updated, it is a good idea to check with Steinberg for further information.
I will close this thread, however, you can open a new thread in case you need further support (you can use this one as a reference) or if you face any issues with our products.
Deivid A.
Looks like the issue persists. I have gotten a new interface. The sound still crackles - but doesn't necessarily drop out.
