Hi everyone,
I'm using a Intel core i7-4790 CPU @ 3.60 and Z97 GAMING 7 (MSI-7916)
The issue occurs randomly, while surfing the web, or playing video games. It usually lasts a couple of hours and will sometimes return to normal but recently its been lasting the entire day with maybe an hour or two when it actually works above 0.79 GHz usually at 1.41 GHz to 3.82 GHz
I've updated my drivers using MSI live update, I have check the CPU temperature and it sits at 30c. I noticed issue when I opened task manager is that despite the utilization of the CPU was fluctuating between 5-20% the speed of the CPU remained a constant 0.79 GHz.
Running Intel processor diagnostic tool showed everything has pass. Even though while the tool was running the speed of the CPU didn't pass the 0.79 GHz threshold.
I haven't done any software changes recently although I installed a new ssd hard drive but the problem existed before I installed the new hard drive.
If anyone could dispense some wisdom it would really help
Thank You
Fan control is a function of the motherboard bios. Update your bios.
Also, re-apply your processor thermal paste.
I've done both now I was able to get some thermal paste from a neighbor and reapplied it. As well as made sure my bios were up to date and the issue is still occurring.
Havic52, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the issue with the Intel® Processor still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Hello Havic52, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
