My i9 13900k will crash any program that tries to use turbo boost, including the Intel Extreme Tuning Utility. I can run the CPU stress test without issue, but as soon as I hit benchmark or any of the other stress tests, the program just quits. It is the same with any program that uses Turbo Boost. I have made no changes to the BIOS defaults nor any changes using the Extreme Tuning Utility.
A quick browse of the internet shows a ton of people with the same issue. They all say to RMA the CPU because it has a bad memory controller.
I ran the intel processor diagnostic tool and it passed. If I turn off Turbo Boost, the system is very stable, but that defeats the purpose of buying a 13900k. Attached are the results from the system support utility. Thanks for any insight on how to fix this. I would rather not have to RMA the CPU.
I would update the bios. You are at F8, the latest is F9c.
https://www.gigabyte.com/Motherboard/Z790-D-DDR4-rev-10/support#support-dl-bios
If you do not know how, contact Gigabyte for support.
Updating the BIOS had no effect. Thanks for the support though!
![](/skins/images/97EBD289F799093125F556C07FADEBA3/responsive_peak/images/icon_anonymous_message.png)
