Hello, I am using the i9 9900k integrated graphics (UHD 630) on my LG Ultragear 27GL850 monitor as I currently dont have a dedicated GPU - This is a 2560x1440p @144hz monitor. I've connected my computer with Display port cable. I have the ASUS ROG strix Z390-F GAMING motherboard.
The problem I have is that when I set my refresh-rate to 144hz, my monitor with flicker badly. As long as I start up my computer with the refresh-rate @120hz, I experience no flickering. But as soon as I try 144hz again, the flickering occurs again. If then I set the refresh rate to lower than 100hz (for example 60hz) my monitor will flicker as well. But when I never touch 144hz and just leave it on 120hz and then switch to 60hz, then 60hz won't flicker.
So basically: If I dont set it to 144hz, everything is fine. But as soon as I set my monitor to 144hz my monitor will flicker, even after switching it back to under 100hz (100-120hz always works).
Things I tried:
- A fresh Windows installation (am currently running the latest version of Windows 10)
- Installing latest UHD 630 drivers
- Different cable
- Resetting monitor settings
- turning HDR and Adaptive-Sync off
- Lowering resolution
I hope someone can help me solve this issue or at least figure out the cause of the issue.
Thanks in advance!
- Tags:
- flickering
- i9 9900k flickering
- monitor flickering
- UHD 630 1440p144hz
- UHD 630 144hz
- UHD 630 flickering monitor
Oh my god, thanks so much! Setting my aspect ratio in OSD to ''Just scan'' FIXED it!
Im really happy, thanks so much for taking the time to help me out!
