I am writing a simple double precision floating point library for a micro controller... and I tested its results vs what my computer calculates.
My computer has a i7-7820HK CPU @ 2.90GHz, 2901 Mhz.
Where I found issues is when I am multiplying two numbers that result in a subnormal/denormal number... sometimes, according to my calculations, my computer (your CPU?) is giving me a result that is rounded incorrectly.
Here are a couple examples:
My lib rounded to higher magnitude, CPU didn't
-1.0913716444947332E-161 * 5.5880945523004242E-148
Lib -6.0986879411361762E-309
CPU -6.09868794113617E-309
Lib 0x800462ab6512d055
CPU 0x800462ab6512d054
CPU rounded to higher magnitude, my lib didn't
6.4439637432002375E-265 * -1.8323993047591027E-44
Lib -1.1807914682932978E-308
CPU -1.1807914682932983E-308
Lib 0x80087da541ae0aa1
CPU 0x80087da541ae0aa2
On inspection of the rounded off bits, it looks like my lib is correct. I'm using: round to nearest, if half, round to even.
Please confirm/test on your system? Fortunately, if this is a hardware bug, it should normally be below the noise floor.
You should be able to verify which rounding is correct using 128 bit floating point math.
Cheers,
Dean
DGore2, Thank you for posting in the Intel® Communities Support.
In this case, we can always run the Intel® Processor Diagnostic Tool, it does an overall testing on the unit and if it passes the test then it means it is working fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Is there any demo or link that you can share in order for us to download the application that you are using to try to replicate this scenario?
Once you get the chance, please let us know the results.
Just to let you know, we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Alberto R.
DGore2, I just received an update on this matter.
At this point the next thing to do will be to make sure that the latest BIOS version is installed in your system, please get in contact directly with the manufacturer of the computer to confirm which is the latest BIOS version available for your platform to install it.
Alberto R.
DGore2, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
I just wanted to let you know that if the problem persists after doing the BIOS update, we recommend to visit, register and submit your inquiry in our Intel® Developer Zone site, where you will receive further peer to peer assistance for this scenario:
https://software.intel.com/en-us/forum
Alberto R.
