Processors
14610 Discussions
the processor of my laptop is i5-4200U Can I change it to i5-9600K or i58600K or I7-8700? does all of those compatible with the motherboard
KALSH
my Laptop is Sony VAIO DUO 13.3
Model : SVD132A14W
I want my laptop to be faster.
AlHill
If it were that simple to go from a 4th gen to a 9th gen processor....
As your processor is soldered to the motherboard (has a BGA socket), so you will never be able to upgrade it.
If it were not soldered, you must still ask Sony what processors are compatible with THEIR BIOS. Then, you could select from those processors. Alas, you cannot do this.
An upgrade processor must be socket, chipset, and BIOS compatible.
Just for comparison purposes, here are the four processors you asked about.
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=75459,126686,126685,134896
Doc
n_scott_pearson
I will add that, except for rare cases (not yours, however), replacement processors must come from the same processor generation. That is, i5-4xxx or i7-4xxx. Al is correct; only Sony can tell you what processor upgrades might be possible (are supported by their BIOS).
H​ope this helps,
