I would like to know the "proper" turbo frequencies on Intel Xeon W-2135. I.e load with 1 core, 2 cores, 3 cores etc.
We are running RHEL7 and measure the turbo frequencies with turbostat command.
Load looks as below for now, but is this according to spec?
1 cores: 4500!!! 4500!!!
2 cores: 4500!!! 4500!!!
3 cores: 4400!!! 4400!!!
4 cores: 4400!!! 4400!!!
5 cores: 4400!!! 4400!!!
6 cores: 4400!!! 4400!!!
Thanks in advance!
Hello flood,
For Maximum Turbo Frequencies for Xeon W-2135, can be found on Intel Ark page:
https://ark.intel.com/products/126709/Intel-Xeon-W-2135-Processor-8-25M-Cache-3-70-GHz- https://ark.intel.com/products/126709/Intel-Xeon-W-2135-Processor-8-25M-Cache-3-70-GHz-, which is 4.50GHz
Or additional information can be found on the following page for other models:
https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/xeon-scalable-w-workstation-brief.pdf https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/xeon-scalable-w-workstation-brief.pdf, Page # 6
https://ark.intel.com/products/series/125191/Intel-Xeon-Scalable-Processors https://ark.intel.com/products/series/125191/Intel-Xeon-Scalable-Processors
I hope this information helps.
Or if you require it for specific modes, please provide me with the model numbers.
If there is anything else we can help please feel free to ask.
Henry A.
Hello Henry,
Thank you for your reply.
what confuses me is that the scaling on "i7-8700K" processor produces the below results when multiple cores are under heavy load.
1 cores: 4700!!! 4700!!!
2 cores: 4600!!! 4600!!!
3 cores: 4500!!! 4500!!!
6 cores: 4300!!! 4300!!!
I am expecting similar results on Xeon w-2135, but my assumptions may be wrong.
Do you know if the Xeon w-2135 _only_ targets 3.7GHz (the base frequency) when multiple cores are put on heavy load?
Then maybe this is expected behavior.
Thanks in advance!
/best regards
Mikael
Hello flood,
I truly understand the confusing between i7-8700K and Xeon-W-2135.
But both process will reach the Max Turbo Frequencies differently.
It depends on the motherboard BIOS to enable all options on the CPU.
It is critical to understand that performance is not just about the number of cores or frequency speed, it is based upon the entire infrastructure that helps transfer data to where it is needed in a high-performance PC, when it is needed, so that it can be transformed into actionable information in the shortest amount of time.
You can find additional information on Google (Xeon vs i7).
Also, what benchmark or test software are you using to the get Max Turbo Frequencies.
And what hardware configuration uses on each CPU.
Henry A.
Hello flood,
I just wanted to follow up and verify if the information provided helpe and please help me with the software been used to test the processor.
Henry A.
Hello flood,
We are following up on a case that is still open with the issue "Xeon W-2135 Maximum Turbo Frequencies", we know that this is important for you to get it resolved and it is also equally important for us to get you the right solution. Since we have not seen an update for 5 days, the case will automatically close after 2 business days. You can still re-open the case by logging into your web portal or replying to this email so that all previous interactions around this case will carry through."
If you have any questions, please let me know.
Henry A.
Hey Henry,
Sorry for the delay. We discovered that it is likely a OS or bios configuration causing these unpredictable CPU frequencies during load.
Various shell commands to provoke load to each individual core, and then we measure the frequency with turbostat (turbostat - Report processor frequency and idle statistics).
The commands are basically emulating load for production.
The motherboard is supermicro
https://www.supermicro.com/products/motherboard/Xeon/C420/X11SRM-F.cfm X11SRM-F | Motherboards | Products - Super Micro Computer, Inc.
Probably we need to look into the bios configuration more.
The default setting (and our current) are as
Speedstep PSD Function (Pstates) Enable
EIST PSD Function HW_ALL
Turbo Mode Enable
Which basically should let the OS (Red hat) query the hardware to adjust frequencies and then let the hardware make a decision.
Thank you for baring with me.
/best regards
Mikael Flood
Hello flood,
Thank you for the updated information.
I thought it could be related to the system board BIOS configuration.
If there is anything I can help please let us know.
Henry A.
I am following up this thread in order to see if you still need more assistance on this or if you have any other question in order to assist you with.
Please, let me know and I will be more than happy to assist you.
Emeth O.
Thank you so much for asking! We will be talking with supermicro to verify BIOS settings instead.
This thread may be closed. Thanks again1
No problem, if you have any other question please do not hesitate and contact us back and we will be more than happy to assist you.
Have a wonderful day.
Emeth O.
