21595 Discussions
1.8V HSTL Differential DDR output using ALTDDIO_OUT on Cyclone 10 LP
I need to drive multiple 1.8V HSTL differential pairs from a Cyclone 10 LP FPGA. The output is DDR, source synchronous.
I am currently doing this with single-ended signals using the ALTDDIO_OUT megafunction. How do I best make each output pin differential instead of single-ended?
From the datasheet, I believe that only the CLKOUT pins support differential HSTL output. So, I must emulate it with two single-ended outputs with one inverted.
I don't seem to be able to tell the pin planner to make the pins a pair (like we do for LVDS).
Any guidance is much appreciated!
Sorry for the original question being confusing. My basic question is how can I use the DDR output registers (thru ALTDDIO_OUT) to drive two pins in a pseudo-differential fashion (one inverted from the other)? What is the suggested approach? I don't think we can invert the output of the ALTDDIO for the negative pin.
Specifically, I'm targeting a Cyclone 10 LP FPGA, with VHDL using Quartus Prime v17.1.
According to the device handbook, 1.8V differential HSTL standard is supported on all IO banks. No need to simulate anything, just assign a pin pair to the logical port.
Thank you for your reply, FvM.
I originally tried to do as you suggest. The pin-planner does not give me the option of 1.8V Differential HSTL Class I on most I/O pins. Digging further in the "Cyclone 10 LP Core Fabric and General Purpose I/Os Handbook", pg 102 says:
the following differential i/o standards are supported only on clock input pins and
pll clock output pins:
— differential sstl-2 and differential sstl-18
differential 1.8 v hstl, differential 1.5 v hstl, and differential 1.2 v hstl
So, I believe I cannot use the differential output standards on normal I/O pins. Or is there something I'm overlooking?
Ultimately, I'm needing 5 differential output pairs to drive a MIPI CSI-2 output. The Altera app note: "AN 754: MIPI D-PHY Solution with Passive Resistor Networks in Intel Low-Cost FPGAs" recommends using the differential 1.8V HSTL outputs.
Maybe the closest I can come is using two single ended 1.8V HSTL outputs. What do you all think? Then my question is how to drive them both from a ALTDDIO_OUT megafunction?
