21594 Discussions
MAX V Support Life
I am planning to switch my design to MAX 5 as the current part that I am using (MAX3000A) has EOL-ed.
Is MAX 5 recommended for new design? Will it EOL in the next 5 to 10 years?
If MAX 5 is not recommended, what is the recommended alternative closest to MAX3000A?
Also, I have some technical questions.
1) When I synthesize my design with MAX3000A using Quartus II version 7.2 SP2, the total Macrocells used is 56.
However, when I synthesize the same design with MAX 5 (5M80ZE64C5N), the total LE used is 117 (greater than the capacity of this part).
5M80ZE64C5N is supposed to contains equivalent of 64 Macrocells, so I am surprise that this part cannot fit the original design.
I look at the .map.rpt file for both the synthesis, and saw something not quite right.
Under the section “Analysis & Synthesis Resource Utilization by Entity”, the resources used by “Frame_signals:inst14”, MAX3000A uses 6 Macrocells, but MAX5 uses 57 logic elements.
This “Frame_signals:inst14” is actually a State machine: "|xxxxx|Frame_signals:inst14|statem" contains 32 states and 6 state bits.
Does MAX3000A and MAX 5 handles state machines differently? Do I need to modify the way I coded the state machines?
Please help. Thanks.
A different macro cell utilization is expectable due to the different architecture. MAX V 4-input-LUT is less effective if a logic term has many inputs.
We need to look at the code to determine if it might be optimized, e.g. by changing the state variable coding. Using a high level description according to Altera state machine templates should generally give good results.
