21611 Discussions
(10036)Can't resolve multiple constate drivers assigment
Im kinda new with Quartus II and VHDL so let's go.
Im projecting a simple CPU. with 4 registers. so i have 2 signals to let the register (normal_buffer) read from the bus or right. those signals are Rin and Rout.
i made a MUX to select who is reading or writing on the given state.
When i trie to compile i get the error (10036)Can't resolve multiple constate drivers assigment at Rin(3).
what this error means? what im doing wrong?
thank you very much
Observation: Please ignore the coments that are not in english. =D
library ieee; use ieee.std_logic_1164.all; LIBRARY CPU; USE CPU.ula_package.all; ENTITY CPU IS port( input: in std_logic_vector(7 downto 0); clock: in std_logic; reset : in std_logic; data: INOUT std_logic_vector(7 downto 0); output: out std_logic_vector(7 downto 0) ); END CPU; ARCHITECTURE test of CPU is type state is (A,B,C,D); signal s : state; signal Rin,Rout : std_logic_vector(0 to 6); signal r1,r2,r3,r4,Y,Z,RI: std_logic_vector(7 downto 0); signal zero: std_logic; signal control: std_logic_vector(1 downto 0); signal sel_code_Rin,sel_code_Rout: std_logic_vector(0 to 2); signal conta : std_logic_vector(7 downto 0); signal i : std_logic; begin P_C : PC port map(data,i); reg1: normal_buffer port map(data,Rin(0),Clock,r1); reg2: normal_buffer port map(data,Rin(1),Clock,r2); reg3: normal_buffer port map(data,Rin(2),Clock,r3); reg4: normal_buffer port map(data,Rin(3),Clock,r4); reg_Y: normal_buffer port map(data,Rin(4),Clock,Y); reg_RI: normal_buffer port map(data,Rin(5),Clock,RI); tri_state_1: tri_buffer port map(r1,Rout(0),data); tri_state_2: tri_buffer port map(r2,Rout(1),data); tri_state_3: tri_buffer port map(r3,Rout(2),data); tri_state_4: tri_buffer port map(r4,Rout(3),data); tri_state_Y: tri_buffer port map(Y,Rout(4),data); tri_state_RI: tri_buffer port map(RI,Rout(5),data); --LIGACAO FEITA. FAZER AS CONTAS! unidade_logica: ULA port map(Y,data,control,zero,conta); reg_Z: normal_buffer port map(conta,Rin(6),clock,Z); tri_state_Z: tri_buffer port map(Z,Rout(6),data); --seleciona qual registador vai escrever no barramento with sel_code_Rin select <= COMPILEER SAYS THE ERROR IS HERE Rin <= "1000000" when "000", --R1 "0100000" when "001", -- R2 "0010000" when "010", -- R3 "0001000" when "011", --R4 "0000100" when "100", --Y "0000010" when "101", --RI "0000001" when "110", -- Z "0000000" when others; -- seleciona qual registrador vai receber dados do barramento with sel_code_Rout select Rout <= "1000000" when "000", --R1 "0100000" when "001", -- R2 "0010000" when "010", -- R3 "0001000" when "011",--R4 "0000100" when "100", --Y "0000010" when "101", --RI "0000001" when "110", -- Z "0000000" when others; process (data,reset,clock) begin if reset = '0' then s <= a; elsif (clock'event and clock = '1') then case s is when A => sel_code_Rin <= "101"; <= I made RI-out i <= '1'; output <= "00000001"; s <= B; when B => case RI(7 downto 5) is when "000" => output <= "00000000"; when "001" => output <= "00000001"; s <= C; when "010" => output <= "00000010"; when "011" => output <= "00000011"; when "101" => output <= "00000101"; when "100" => output <= "00000100"; when others => output <= "00000111"; end case; when C => Rin(3) <= '1'; s <= D; when D => control <= "00"; when others => output <= "11111111"; s<= A; end case; end if; end process; end test;
Just found my error...
thanks
the administrator can delete/lock the post.
