21616 Discussions
10M25DAF484C8G clock input
joe_su
Hi
we have serveral CML clocks output from ethernet PHY which is connected to 10M25DAF484C8G pin P3/R3, V9/V10, how to design the convertion circuit as CML(PHY) to LVDS(max10) ?
and if we want to output these diff-clock signal, what type it should be ? what type diff-clock does 10M25DA support output ?
//Joe
ShengN_Intel
If voltage of CML and LVDS are not the same, can use below:
If low speed, you can use voltage divider.
If high speed, you need to use level shifter.
If voltage of CML and LVDS are same, not need to use.
And also the external termination circuit:
https://www.intel.com/content/www/us/en/docs/programmable/683760/22-1/lvds-1-8-v-lvds-mini-lvds-and-rsds-receiver.html
The Max 10 lvds IO Standard can refer this :
https://www.intel.com/content/www/us/en/docs/programmable/683760/24-1/lvds-serdes-i-o-standards-support.html
Sheng
joe_su
Hi ShengN
one morequestion
I used 10M25DAF484C8G, I need pin L8/L9 configure as diff LVDS output. but IO_1B is on 3.3V power rail.
is it can work on output diff-LVDS clock signal ?
//Joe
ShengN_Intel
This is example of level shifter:
https://www.analog.com/en/products/max9376.html
Guarantee for high speed.
Sheng
FvM
you usually don't need a level shifter for clock signal. For clock belo 500 MHz, MAX 10 LVDS input has 0.05 - 1.8 V common mode range which most likely fits the CML signal. If not, you can use AC coupling with bias to 1.25 V on the FPGA side.
Similarly, LVDS output driver will most likely fit level requirements of CML input on other device.
Frank
ShengN_Intel
ShengN_Intel
Hi Joe,
Reply to this post community.intel.com/t5/Programmable-Devices/10M25DAF484C8G-clock-input/m-p/1718285#M101342:
No. Check this https://www.intel.com/content/www/us/en/docs/programmable/683760/22-1/lvds-channels-support.html
However, only the bottom I/O banks support true LVDS output buffers.
Intel® MAX® 10 I/O Banks Locations:
https://www.intel.com/content/www/us/en/docs/programmable/683105/current/i-o-banks-locations.html
Sheng
