21588 Discussions
128 bit master to 32 bit slave
Hi ,
I am connecting a master whose data width is 128 bit. I am connecting it to a slave whose data width is 32 bit.
Master output is Avalon interface
When I trigger a data from the master, it is triggering 4 writes on slave.(32*4 =128).But that will overwrite the data in the next address. How do I tell my interconnect to consider only LSB 32 bit? Is there any setting that can be modified?
You can use the byteenable signal thats part of the Avalon standard to mask certain bytes.
--- Quote Start ---
--- Quote End ---
My master is a pcie hard IP configured as G3x4 128bit 250 MHz. You mean I have to manually hack the interconnect file generated by Qsys between the pcie(rxm port) and my apb slave??
Try doing a write of 4 bytes rather than 16.
