Programmable Devices
21597 ディスカッション
148-pin QFN case on 1 mm PCB
名誉コントリビューター II
2,179件の閲覧回数
In its Cyclone 4 family Altera introduced new 148-pin QFN case.
What is the reason to recommend rather thin PCB, <0.8 mm, for this case?
Is it PCB thermal expansion? And what can I do if I need 1 or 1.6 mm, e.g. because of edge connector? If I use some laminate other from FR4 for my PCB, could it help?
0 件の賞賛
4 返答(返信)
名誉コントリビューター II
770件の閲覧回数
there is an answer in the knowldege base :
http://www.altera.com/support/kdb/solutions/rd07052010_123.html
If you have a PCB thicker than > 0.8mm you should use a BGA package.
HJS
名誉コントリビューター II
770件の閲覧回数
Hi HJS,
Thank you for the reference. Unfortunately I can not use a BGA, it's too large. There's absolutely no way to fit it into that PCB. And it is very difficult to make a complicated PCB, 0.8 mm thick in one area, 1.6 in another one.
So I'd be happy to know what is the problem exactly, is it just because of different PCB thermal expansion during assembly? If yes, is it reasonable to choose some other material for my PCB, rather than FR4?
名誉コントリビューター II
770件の閲覧回数
I'd use the recommended 0.8 mm FR4 with surface-mount connectors.
名誉コントリビューター II
770件の閲覧回数
The knowledge base explanation isn't particularly clear. But there's no other thinkable reason than thermal expansion in my opinion. It's your decision if you follow the Altera suggestion or ignore it. I think, there's a lot of chip packages that are exposed to similar specific solder joint forces due to thermal expansion.
返信
