21602 Discussions
16 bit Processor for MAXII
Yeah I know it's a NIOS forum, but since NIOS doesnt support MAXII (or is that vice versa?) then here is a solution for those who are interested.
This is a project and assembler for the Altera MAXII demo board.
Steve.
steveg -
When I get an error when I attempt to unzip tiny16.zip. Is there a problem with this .zip file?
--- Quote Start ---
originally posted by bjskill@Dec 31 2004, 01:27 PM
steveg -
when i get an error when i attempt to unzip tiny16.zip.  is there a problem with this .zip file?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=3633)
--- quote end ---
--- Quote End ---
Hi steve,
There is no problem with the zip file. I extracted and compiled the design. It&#39;s OK!
I am amazed to see the fitter results--only 833 LEs.
I will try to add it to my SOPC system as an avalon master component. It&#39;s ideal for my "hardware task sheduler" project.
By the way, I have tried a 8051 core as an avalon master. It works well, but the LE usage is about 3000.
Thank you!
I am working on a more efficient version - the base core is hopfully going to finish around 400LE ... I will post here as version two soon. I am working on a very basic Forth compiler for it also.
Steve.
--- Quote Start ---
originally posted by riple+may 17 2006, 02:59 am--><div class='quotetop'>quote (riple @ may 17 2006, 02:59 am)</div>
--- quote start ---
<!--quotebegin-bjskill@Dec 31 2004, 01:27 PM
steveg -
--- quote end ---
--- Quote End ---
Hi steve,
Thank you!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15423)</div>
[/b]
--- Quote End ---
