21615 Discussions
5CEFA5 Power-up & JTAG problem
JTAG can not find the device, so I check the nSTATUS and CONFIG_DONE signal.
It's weird that nSTATUS and CONFIG_DONE signal are high before I configure the device.
The board is a new one and the flash is empty, why CONFIG_DONE signal high before I configure the device ?
There are some other problems about this board, as follows,
1, Power-up sequence is not the same as datasheet.
2, Power-rail has some noise.
But I think maybe they are not the problem, there maybe some problem else.
Is there anyone met this problem before?
Thank you
