21602 Discussions
A bug in qmegawiz command line?
I want to use qmegawiz command line generate a 2 ports ram with clock_a and clock_b.
"qmegawiz -silent module=altsyncram -f:ram_params.txt myram.v"
the content in file ram_params.txt as follows:
address_aclr_a=NONE
address_aclr_b=NONE
address_reg_b=CLOCK1
indata_aclr_a=NONE
indata_aclr_b=NONE
indata_reg_b=CLOCK1
intended_device_family=Stratix
lpm_type=altsyncram
numwords_a=256
numwords_b=1024
operation_mode=BIDIR_DUAL_PORT
outdata_aclr_a=NONE
outdata_aclr_b=NONE
outdata_reg_a=UNREGISTERED
outdata_reg_b=UNREGISTERED
power_up_uninitialized=FALSE
read_during_write_mode_mixed_ports=DONT_CARE
widthad_a=8
widthad_b=10
width_a=4
width_b=1
width_byteena_a=1
width_byteena_b=1
wrcontrol_aclr_a=NONE
wrcontrol_aclr_b=NONE
wrcontrol_wraddress_reg_b=CLOCK1
but the result file myram.v is only one clock! as follows;
altsyncram_component.address_aclr_a = "NONE",
altsyncram_component.address_aclr_b = "NONE",
altsyncram_component.address_reg_b = "CLOCK0",
altsyncram_component.indata_aclr_a = "NONE",
altsyncram_component.indata_aclr_b = "NONE",
altsyncram_component.indata_reg_b = "CLOCK0",
altsyncram_component.intended_device_family = "Stratix",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 256,
altsyncram_component.numwords_b = 1024,
altsyncram_component.operation_mode = "BIDIR_DUAL_PORT",
altsyncram_component.outdata_aclr_a = "NONE",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_a = "UNREGISTERED",
altsyncram_component.outdata_reg_b = "UNREGISTERED",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE",
altsyncram_component.widthad_a = 8,
altsyncram_component.widthad_b = 10,
altsyncram_component.width_a = 4,
altsyncram_component.width_b = 1,
altsyncram_component.width_byteena_a = 1,
altsyncram_component.width_byteena_b = 1,
altsyncram_component.wrcontrol_aclr_a = "NONE",
altsyncram_component.wrcontrol_aclr_b = "NONE",
altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK0";
when i use gui to genrate 2 pots ram with clock_a and clock_b
the parameter is just as follows: only CLOCK1
altsyncram_component.address_reg_b = "CLOCK1",
altsyncram_component.indata_reg_b = "CLOCK1",
altsyncram_component.numwords_a = 32,
altsyncram_component.numwords_b = 64,
altsyncram_component.widthad_a = 5,
altsyncram_component.widthad_b = 6,
altsyncram_component.width_a = 8,
altsyncram_component.width_b = 4,
altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK1";
In your last example, with clock_a and clock_b, I only see one clock, CLOCK1, mentioned anywhere. Where do you see another clock? (I haven't studied these to really know them..)
In "Quartus II Handbook Version 8.1 Volum 2 Design Implementation and Optimization"->The MegaWizard Plug-In Manager->Ports and Parameters->Strategies to Determine Port and Parameter Values
would you give me an example with 'port and parameter configuration in command line' ?
