21602 Discussions
A new Altera USB Blaster, Rev C stopped working. Error code given in programming software says: BAD 209012 Operation Failed.
LJens1
Altera USB Blaster, Rev C for programming. I have moved this USB blaster to another computer, same issue. Another blaster was put on this computer, same setup, worked.
Is there any way to get this blaster to work?
ShafiqY_Intel
Hi LJen1,
The error message 209012 can be caused by one of the following situations:
  • Communications cables not securely connected
  • Incorrect device selected
  • No power to target system
Have you try command "jtagconfig' your new USB Blaste device? and, please show me the screenshot of jtagconfig.
  • open Command Prompt ---> go to Quartus directory <Quartus installation directory>intelFPGA\18.1\quartus\bin64> ---> run jtagconfig
Cheers
