21615 Discussions
AC Timing Parameters for IO pins in Cyclone V 5CEBA7F27C8N
ShivaKi
For Cyclone V part 5CEBA7F27C8N,  using the IO pins for communication Interface with any external IC, what is the AC timing parameters for IO Pins.
In datasheet, AC Characteristics/timing data for IO Interface or pins is not available. Could you please provide the IO pin AC Characteristics information/references?
Ash_R_Intel
May I know which IO standard are you using? Based on the IO standard used, refer the I/O Standard Specifications section in the datasheet for the voltage requirements. For the timing, it depends upon the design, so, please refer to the Quartus Timing Analyzer for detailed report.
