21611 Discussions
ALT_LVDS timing fails for core clock
I'm using Quartus 13.1 with a Stratix IV GX dev kit.
Trying to implement a simple test design for a 6 bit deserialiser using ALT_LVDS Rx.
But I'm getting timing errors in a weird place.
The register at the outputs of the LVDS_Rx megafunction. The slow clock.
Timequest says the launch clock is the dast clock (480MHz). The latch clock is the slow clock (80MHz).
And there are hold errors.
I don't see why these exist.
Is there something wrong with the way I am reading them?
Its a simple design. 8 channels Lvds Rx with 6 bit deserialiser. Slow speeds.
Feeds to a DC FIFO.. But I can't meet timing according to quartus..
Attached a couple of screenshots if it helps.
ZubairLK
https://www.alteraforum.com/forum/attachment.php?attachmentid=8454 https://www.alteraforum.com/forum/attachment.php?attachmentid=8455
--- Quote Start ---
The reference design that came with it had it disabled? If so, could you file an SR or attach a link to the project? That should not be the case, and is cruel to figure out.
--- Quote End ---
Yes. Submitted an SR.
Edit : http://www.altera.co.uk/products/devkits/altera/kit-siv-gx.html This kit. The 230 edition.
