21611 Discussions
ALTLVDS TX IP - pin location constraints
kikoss
New Contributor II
Hello
I Instantiated on my design an ALTLVDS TX module  for agilex7 , and the compilation passed
This ALTLVDS TX  module output 4 differential ports (configured to 192Mbps each one )  + 1 differential CLK
I constraint those 4 data ports + 1 CLK  port to be located whithin  differential I/O  , 2F bank as the following :
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_1N
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_1P
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_2N
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_2P
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_3N
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_3P
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_4N
set_location_assignment IOBANK_2F -to TX_LVDS_ADC_4P
set_location_assignment IOBANK_2F -to TX_ADC_Data_Clock_P
set_location_assignment IOBANK_2F -to TX_ADC_Data_Clock_N
However the fiitter stage failed and thats the mesg :
Error(175020): The Fitter cannot place logic pin in region (226, 0) to (240, 0), to which it is constrained, because there are no valid locations in the region for logic of this type.
Info(14596): Information about the failing component(s):
Info(175028): The pin name(s): TX_LVDS_ADC_1P
Info(175015): The I/O pad TX_LVDS_ADC_1P is constrained to the region (226, 0) to (240, 0) due to: User Location Constraints (IOBANK_2F)
Info(14709): The constrained I/O pad is contained within this pin
Mean that I give quartus to choose exact  PIN location ,  but quartus don't accept the fact that those PINS are connected to bank2F
Where can I find out what are the detailed rules quartus follows so i can apply appropriate constraint ?
Thx
Kikoss
Labels (2)
FvM
did you assign LVDS IO standard? Did you try to assign explicite pin locations for differential pairs? You only need to assign positive pins, negative pin will be assigned by fitter automatically.
FvM
kikoss
New Contributor II
Hello
You right , need to set IO standard , seems quartus use default for ALTLVDS RX IP but not for ALTLVDS TX IP
Here is the standard I set :
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to CLKINP -entity safety_top_level
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to TX_LVDS_ADC_2P -entity safety_top_level
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to TX_LVDS_ADC_3P -entity safety_top_level
THX
AqidAyman_Intel
Did the issue resolved after you assign the differential I/O standard for the pins?
Aqid
kikoss
New Contributor II
 Hello Yes, I accept it as solution ...
THX
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
