21611 Discussions
MAX10 FPGA pof-file programming fails
Linfeng-Ye
Hi all, I build a custom 10M02SCM153 board, when I attempt to download the .pof file, I got "Error (209012): Operation failed" at 4%. However, I can .sof can be loaded. Could anyone provide some hints to debug it?
Thanks in advance.
Linfeng
FvM
did you try with programmer option "Halt on-chip configuration controller"?
It may be also the case that your board hardware is trying to reconfigure the FPGA.
Frank
GLees
New Contributor II
Just a heads-up, and this may have nothing to do with your problem, but the MAX10 has a bug when programming .pof.  All the pins are supposed to be floating during configuration, but some get configured as outputs and may contend with chips on the board that are trying to drive those pins.  This can cause high current and weird problems.  There is a way to get around it by selecting a particular programming option, but I forget what that is at the moment.
NurAiman_M_Intel
Have you try the suggestion from our friends? Any update?
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
llbb
