21615 Discussions
ALTLVDS external clock
Hi all,
I'm trying to implement the ALTLVDS_RX in a cyclone V.
i would to connect the rx_enable and the rx_inclock to a fpga i/o (lvds dedicate input clock pins).
is it possible?
For now I'm stuck to the error:
"error: ir fifo userdes block node 'lvds_rx:lvds_rx_inst0|altlvds_rx:altlvds_rx_component|lvds_rx_lvds_rx:auto_generated|sd2' is not properly connected on the 'writeclk' port.
it must be connected to one of the valid ports listed below.
info: can be connected to loaden port of arriav_pll_lvds_output wysiwyg
info: can be connected to outclk port of generic_pll wysiwyg
info: can be connected to lvdsclk port of cyclonev_pll_lvds_output wysiwyg info: can be connected to outclk port of arriav_clkena wysiwyg (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd02152013_340.html)"
If I use the relate solution (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04102013_389.html), my quartus crash during the synthesis.
I think that the primitive cyclonev_pll_lvds_output needs a pll, but I have not a pll before the ALTLVDS_RX.
So, the question is:
can i use an altlvds_rx without pll?
Thank you.
It seems that you are trying to build an LVDS application with external clock.
You can reference to the LVDS Userguide IP under the external clock chapter
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_altlvds.pdf
I believe there should be a section with a guidelines on how to set the following 3 things you had mentioned --> LOADEN, OUTCLK, LVDSCLK
There is a parameter editor allow you to choose the "Use External PLL option".
You can refer to the ALTLVDS IP core in external PLL mode from LVDS user guide for more details.
you are seeing the bunch of errors because you didnt put in a buffer.
Refer to below kdb:
It will teach you how to put in the buffers.
The error will go away after that.
Hi all,
dear ah_zhi02,
when you talk about "the external clock chapter" are you referring to "ALTLVDS IP Core in External PLL Mode" p. 62?
I have not found an external clock chapter and the guidelines p 62 are for the external pll. I don't want to use any pll. All my clocks are generated externally to the FPGA.
dear irish,
I'm already using the External PLL option but the clock that I want to use are coming from a FPGA pin. They are not coming from a pll.
dear nicejob,
I have already used the solution https://www.altera.com/support/suppo...02013_389.html. The problem is that I think that the primitive cyclonev_pll_lvds_output needs a pll, but I have not a pll before the ALTLVDS_RX.
When I use a cyclonev_pll_lvds_output my quartus crash during the synthesis.
The clock must come from a PLL. These are dedicated paths laid out for minimal skew/max performance. This allows the dedicated LVDS circuitry to run at a much higher rate, although it loses some flexibility.
(There are three outputs from the PLL that must be in sync with each other, the high-speed clock, the low-speed clock, and the load enable signal. I'm not sure how you're planning on doing this without a PLL).
