Programmable Devices
21611 Discussions
ALTPLL's problem
I'm using a ATLPLL IP In my design. This PLL has one input clock, one areset, one Lock output and one output clock.
The input clock is 50MHz (I wrote 45MHz) . The PLL outputs should be 100MHz.
The code is not working (after reset I get the following meassage:"# ** Fatal: (SIGFPE) Floating point exception").
The ALTPLL's connections as below:
PLL port map (
areset => reset, --constant '0'
inclk0 => CLOCK_50,
c0 => PLL100MHz, --100Mhz expected clock
locked => locked);
The ALTPLL's setting is below:
bandwidth_type => "AUTO",
clk0_divide_by => 9,
clk0_duty_cycle => 50,
clk0_multiply_by => 20,
clk0_phase_shift => "0",
compensate_clock => "CLK0",
inclk0_input_frequency => 22222,
intended_device_family => "Cyclone III",
lpm_hint => "CBX_MODULE_PREFIX=PLL",
lpm_type => "altpll",
operation_mode => "NORMAL",
pll_type => "AUTO",
port_activeclock => "PORT_UNUSED",
port_areset => "PORT_USED",
port_clkbad0 => "PORT_UNUSED",
port_clkbad1 => "PORT_UNUSED",
port_clkloss => "PORT_UNUSED",
port_clkswitch => "PORT_UNUSED",
port_configupdate => "PORT_UNUSED",
port_fbin => "PORT_UNUSED",
port_inclk0 => "PORT_USED",
port_inclk1 => "PORT_UNUSED",
port_locked => "PORT_USED",
port_pfdena => "PORT_UNUSED",
port_phasecounterselect => "PORT_UNUSED",
port_phasedone => "PORT_UNUSED",
port_phasestep => "PORT_UNUSED",
port_phaseupdown => "PORT_UNUSED",
port_pllena => "PORT_UNUSED",
port_scanaclr => "PORT_UNUSED",
port_scanclk => "PORT_UNUSED",
port_scanclkena => "PORT_UNUSED",
port_scandata => "PORT_UNUSED",
port_scandataout => "PORT_UNUSED",
port_scandone => "PORT_UNUSED",
port_scanread => "PORT_UNUSED",
port_scanwrite => "PORT_UNUSED",
port_clk0 => "PORT_USED",
port_clk1 => "PORT_UNUSED",
port_clk2 => "PORT_UNUSED",
port_clk3 => "PORT_UNUSED",
port_clk4 => "PORT_UNUSED",
port_clk5 => "PORT_UNUSED",
port_clkena0 => "PORT_UNUSED",
port_clkena1 => "PORT_UNUSED",
port_clkena2 => "PORT_UNUSED",
port_clkena3 => "PORT_UNUSED",
port_clkena4 => "PORT_UNUSED",
port_clkena5 => "PORT_UNUSED",
port_extclk0 => "PORT_UNUSED",
port_extclk1 => "PORT_UNUSED",
port_extclk2 => "PORT_UNUSED",
port_extclk3 => "PORT_UNUSED",
self_reset_on_loss_lock => "OFF",
width_clock => 5
What's wrong with my design?
Idan
The ALTPLL must have "reset" at the beginning.
Sim resolution must be: "ps":-P
