21611 Discussions
Access Violation with 22.3 programmer
UMEPU
Dear Sirs.
I am trying to write a very simple SOF to my Stratix10GX (1SG085HN3F43E1VG) board with Quartus  22.3 and Windows10 64bit.
I get the message as followings: (GUI show 23%)
Info: Command: quartus_pgm -c 1 -m jtag -o p;sample_top.sof@2 --debug
Info (213045): Using programming cable "USB-BlasterII [USB-1]"
Info (213011): Using programming file sample_top.sof with checksum 0x1DD1ADD3 for device 1SG085HN3F43@2
Info (209060): Started Programmer operation at Mon Nov 21 16:02:09 2022
Info (18942): Configuring device index 2
*** Fatal Error: Access Violation at 00007FFE8FECA5BA
Module: quartus_pgm.exe
Stack Trace:
  Quartus         0x11a5b9: PGMALGO_API_PGM::send_s10_program_data + 0xba9 (pgm_pgmalgo)
  Quartus         0x160cf8: PGMALGO_DO_SDM_CONFIGURE::execute + 0x1948 (pgm_pgmalgo)
  Quartus          0x656c9: PGME_UNIFIED_ALGORITHM::do_algo + 0x3b39 (pgm_pgme)
  Quartus          0xc8a43: PGME_UNIFIED_ALGORITHM::program + 0x553 (pgm_pgme)
  Quartus          0x6dea8: PGME_PROGRAMMER::engage + 0x1388 (pgm_pgme)
  Quartus          0x377d6: QPGM_FRAMEWORK::execute + 0x1126 (quartus_pgm)
  Quartus          0x1fdcc: qexe_do_normal + 0x4cc (comp_qexe)
  Quartus          0x29753: qexe_run + 0x683 (comp_qexe)
  Quartus          0x2aa0a: qexe_standard_main + 0x26a (comp_qexe)
  Quartus          0x4ca0b: qpgm_main + 0x6b (quartus_pgm)
  Quartus          0x27b68: msg_main_thread + 0x18 (CCL_MSG)
  Quartus          0x28b22: msg_thread_wrapper + 0x82 (CCL_MSG)
  Quartus          0x2aae3: mem_thread_wrapper + 0x73 (ccl_mem)
  Quartus          0x25088: msg_exe_main + 0x178 (CCL_MSG)
  Quartus          0x4fc2b: __scrt_common_main_seh + 0x10b (quartus_pgm)
  Quartus          0x174b3: BaseThreadInitThunk + 0x13 (KERNEL32)
  Quartus          0x526a0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Do you have any idea about this error message?
MSEL is AS fast-mode, and I cannot change MSEL (too narrow space to change).
I can write SDM default SOF to write JIC file and verify is also good.
I try to write SOF with 22.2 and 20.3, but it is also failed. (error message is different)
If you have any idea which I should try or anything, please let me know.
Thank you for your cooperation.
With Best Regards.
UMEPU
Dear Fakhrul
Yes Quartus programmer. But now it seems to be OK. After reboot my PC, Quartus Programmer is working well.
With Best Regards.
  -- toshi//
Fakhrul
Hi UMEPU,
Have you tried to use the Quartus programmer?
Is there any error?
Fakhrul
UMEPU
Dear Fakhrul
With Best Regards.
  -- toshi//
Fakhrul
Hi UMEPU,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Fakhrul
