- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I need help with reading/writing files, from the NIOS II target with a PC file. My IDE is ECLIPSE, so: I don't have the project->properties->Associated system Library->System Library oroerties->Software Components->add this SW Component. So what's its equivalent. Thanks:confused: YossiLink kopiert
4 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
In other words, I can't get into the if:
int x; char list[30]= {"ABCOCJHAKLSDNJCDKLASNC"}; FILE *fd; if( (fd = fopen("a.txt", "w+t")) != NULL) { x = fwrite(list, sizeof(char), 12, fd); fclose(fd); } if( (fd = fopen("a.txt", "r+t")) != NULL) { x = fread(list, sizeof(char), 12, fd); fclose(fd); }- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi, jberman!
To read your files from ext. Flash memory for NIOS II 9.1: BSP Editor -> Software packages -> activate altera_ro_zipfs. -ro_zipfs_base - base of your Flash memory. I haven't found how to create "zip file" with my original files to load it to Flash memory . Write this "zip file" to Flash using Flash Programmer. And use fp = fopen ("/mnt/rozipfs/file1.txt", "r"); and so on If you know how to create "zip file", to load it to Flash memory, share with me. Manual doesn't tell it clearly. altera.com/literature/hb/nios2/n2sw_nii52012.pdf- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi!
The answer: Michael72 altera_ro_zipfs niosii for eclipse .- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- Hi, I need help with reading/writing files, from the NIOS II target with a PC file. My IDE is ECLIPSE, so: I don't have the project->properties->Associated system Library->System Library oroerties->Software Components->add this SW Component. So what's its equivalent. Thanks:confused: Yossi --- Quote End --- I meet the same difficult,have you solved you problem?
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
