Hi All,
I have been trying to create an adder array which is capable of adding three 10 bit numbers together. I have it working with unsigned numbers, but as soon as I try any signed numbers, the result is totally wrong. See images... https://alteraforum.com/forum/attachment.php?attachmentid=13525&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=13527&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=13528&stc=1 This is likely something simple to experienced users out there, so any help would be appreciated :) Thanks.連結已複製
I have used the twos complement number system to carry out the sign operation on the input, this has been simulated and works correctly. An original unsigned input of 0 to 31 has been replaced with a signed input of 0 to -16 and 0 to +15.
There are two unsigned inputs, a0-a4 and b0-b4. These are converted to signed using the twos compliment number system and multiplied to give a 10 bit output. The output is clocked into a 10 bit d-type flip flop array. The unsigned inputs are then changed to a different number, repeating the process above another two times with different d-type flip flop arrays. This gives three 10 bit outputs, which then need to be added together. (This is for a matrix multiplier). I need the sign extension as the circuit needs to be able to accept both signed and unsigned numbers.
I'm using the count function to generate the test vectors. The problem I'm getting looks like this. When testing, (511+255+127 = 893). That's absolutely fine, working no problem. As soon as a negative number is included, the problem arises. Example from testing, (-512+256+128 = 896). Obviously this should be displaying an answer of -128! I've tried around 40 different combinations of adders and keep hitting the same issue...I have a 12 bit output, this is why I don't understand the issue! And unfortunately I have only been taught to use Block Diagrams. (I use the term taught loosely, more like self taught). I'd love to learn verilog but I simply don't have the time :(
As 10-bit hex numbers 896 and -128 are identical (0x380). But as 12-bit hex numbers 896 = 0x380 and -128 = 0xF80. Are you sure your output is signed and 12 bits? What do you get if you add 511 + 511 + 511? How about -1 + -1 + -1? And how about -512 + 0 + 0?
Play with different numbers and the problem should eventually become obvious.
