21611 Discussions
Adding SSRAM for Reset and exception vector in NIOS2(sopc builder)
hi,
I m using ssram CY7C140V33, which is not part of the SOPC builder SSRAM Controller.So i Created the new component for this SSRAM(added signals and interfaces). after adding to the SOPC system, im not able to add this SSRAM to Reset and exception vector of the NIOS2 cpu
I need help
regards,
Gajanan
Did you define your custom component as a memory component? If not, SOPC Builder will not see your SSRAM as a viable component for the reset and exception vectors.
Ben
Thank you Ben for the reply
How do i add the custom component as memory component in the sopc builder ?
Gajanan
Add the following to your IP TCL file generated by SOPC (after you created component in SOPC)
--- Quote Start ---
set_interface_property <interface_name> isMemoryDevice true
--- Quote End ---
<interface_name> is the name that defined by SOPC
thanks for support
it's working fine
regards,
Bhandari
