Programmable Devices
21602 討論
After watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
KWang97
初學者
6,132 檢視
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-config(watchdog enable checkbox checked) and set watchdog value to any value, the link led will be on for about 2 seconds and return to be off. This will also be repeated after dozens of seconds. Why? How will I use the watchdog for dual-config? I didn't run remote update after power-up and the FPGA just run application firmware(just ethernet communication with another FPGA using PHY chip).Untitled.png
Attached file is my fpga code for the dual-config.
0 積分
54 回應
KWang97
初學者
2,743 檢視
JohnT_Intel
員工
2,743 檢視
From the FPGA code, I do not observed that you performed watchdog timer reset. You will need to assert RU_nRSTIMER  since you enable the watchdog timer. Please refer to table 34 in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf in order to performed watchdog timer reset
KWang97
初學者
2,743 檢視
        At the end of the code, I reset watchdog together with set reconfig by assigning sl32avmm_rcv_writedata <= X"00000003";  Is this not right?
    slavmm_rcv_write <= '1';
            sl3avmm_rcv_address <= B"000";
JohnT_Intel
員工
2,743 檢視
The write data X"00000003" will assert both trigger reconfiguration and reset the watchdog timer. The write data should be X"00000002" as this will set the bit 1 reset watchdog timer only.
KWang97
初學者
2,743 檢視
Will i need to ​  reset watchdog timer frequently, or just at the time when I need reconfiguration?@JohnT_Intel​
JohnT_Intel
員工
2,743 檢視
You just need to performed once after you reconfigure the Max 10 device.
KWang97
初學者
2,743 檢視
Will the code below OK? But after write sl32avmm_rcv_writedata <= X"00000001"; then FPGA will be reconfiged, I guess FPGA will not receive   reset cmd sl32avmm_rcv_writedata <= X"00000002";      How should I set reconfig and watchdog reset in my code? Thanks!@JohnT_Intel​
(50Mhz clock)
 when ST_DUALCONFIG_TRIGGER =>
          slavmm_rcv_read <= '1';
          sl3avmm_rcv_address <= B"011";
          if sl32avmm_rcv_readdata(0) = '0' then
            stDualConfigState <= ST_DUALCONFIG_TRIGGER_DONE;
          end if;
        when ST_DUALCONFIG_TRIGGER_DONE =>
        when others =>
          null;
      end case;
JohnT_Intel
員工
2,743 檢視
It looks good but there is still some problem where the state machine will be reset whenever you trigger the reconfiguration. So I do not think that it will go to ST_DUALCONFIG_TRIGGER_DONE state. You will need to modify your code so that when the Application image is loaded then you will performed watchdog timer reset.
KWang97
初學者
2,742 檢視
I modified my code like below. Is this OK?  But PHY communication still not work normally. Once I disable the " watchdog enable checkbox" it's OK while after enable it, it will not be OK. I reset watchdog only once at the initial state highlighted with bold character.
DualConfig0 : process( plClk )
  begin
    if rising_edge( plClk ) then
      slavmm_rcv_read <= '0';
      slavmm_rcv_write <= '0';
      sl32avmm_rcv_writedata <= X"00000000";
      case stDualConfigState is
        when ST_DUALCONFIG_IDLE =>
          if slGoReboot = '1' then
            if slToBeErase = '0' then
              stDualConfigState <= ST_DUALCONFIG_WRWAIT;
              sl3avmm_rcv_address <= B"001";
              sl32avmm_rcv_writedata <= X"00000001"; -- application image(image0)
            end if;
            if slFaultRetrigger = '1' then
              sl32avmm_rcv_writedata <= X"00000003"; -- factory image(image1)
            end if;
          end if;
          if slWatchdogResetFlg = '0' then
            slWatchdogResetFlg <= '1';
          end if;
        when ST_DUALCONFIG_WRWAIT =>
          stDualConfigState <= ST_DUALCONFIG_READ;
        when ST_DUALCONFIG_READ =>
          stDualConfigState <= ST_DUALCONFIG_RDWAIT;
        when ST_DUALCONFIG_RDWAIT =>
          stDualConfigState <= ST_DUALCONFIG_TRIGGER;
          end if;
          null;
        when others =>
          null;
      end case;
    end if;
  end process;
KWang97
初學者
2,743 檢視
JohnT_Intel
員工
2,744 檢視
May I know what do you mean PHY communication is not working? The dual configuration and watchdog timer shouldn't impact your PHY communication. Could you check if your design is working correctly?
KWang97
初學者
2,744 檢視
Ir shouldn't influnce the PHY comminication and I also wonder why. But PHY comminication works well when I disable the watchdog. While after I enable watchdog, the PHY communication works unnormally. Every dozens of seconds the communication will be missing for around 2 seconds. It seems like the PHY is reset. But I don't know why?
And is what I modified in the code for reseting watchdog right? Thanks!
@JohnT_Intel​
JohnT_Intel
員工
2,744 檢視
May I know how do you confirm if the correct image is loaded into the FPGA? Does both image will have the PHY communication work? Is there any different between the 2 image?
KWang97
初學者
2,744 檢視
I programmed the same pof file into both image0 and iamge1.
JohnT_Intel
員工
2,744 檢視
May I know if you observed PHY communication down, do you observed the image reconfigure? Are you able to check if you assert the reset the watchdog timer correctly?
KWang97
初學者
2,744 檢視
Yes, I see PHY communication down with Link LED on while it should be always off in normal situation.
The image didn't reconfigure because I didn't trigger it at all. And other parts of my code runs normally.
As to the Are you able to check if you assert the reset the watchdog timer correctly, that's what I am discussing with you and I also upload the code above 30minutes ago. So please help me see if it's OK?
@JohnT_Intel​
JohnT_Intel
員工
2,744 檢視
The code looks goods. I just ask to double confirm in hardware but since you mention that reconfiguration is not happening is not happening then it should be fine. You will need to further debug what is actually happening that cause teh PHY communication to be down.
KWang97
初學者
2,744 檢視
It happens once I enable the watchdog , even I didn't use dual-config IP(write any code to dual-config IP). so I wonder why this can influnce PHY communication.@JohnT_Intel​
JohnT_Intel
員工
2,744 檢視
Could you increase the watchdog timer to 0x1FFF?
KWang97
初學者
2,733 檢視
I wonder why is 0x1FFF? The value should be 12 bits while 0x1FFF has 13 ones.
回覆
