Programmable Devices
21598 Discussions
Agilex 5 FPGA E-Series Configuration Flash Memory
Nicole04
Nouveau contributeur I
700 Visites
Good day,
I would like to use the Active Serial (AS) configuration scheme for configuring the Agilex 5 FPGA. I see the Device Configuration User Guide: Agilex™ 5 FPGAs and SoCs gives a list of compatible flash memory in Table 32. I would like to use a QSPI flash device from ISSI, IS25WP512M-RHLE, this device has a dedicated reset pin. Will I be able to use this device?
Kind regards,
Nicole
Étiquettes (1)
0 Compliments
Fakhrul
Employé
597 Visites
Hi Nicole04,
Any Quad SPI flash devices that meet both the following criteria, should be supported.
  • Supports Serial Flash Discoverable Parameter (SFDP) standard
  • Supports dedicated pin reset
Fakhrul
Voir la solution dans l'envoi d'origine
0 Compliments
2 Réponses
Fakhrul
Employé
598 Visites
Hi Nicole04,
Fakhrul
0 Compliments
Fakhrul
Employé
525 Visites
Hi ,
I noticed you marked my earlier comment as the solution. I'm glad your question has been addressed!
At this point, I’ll transition this thread to community support. If you have any new questions, feel free to open a new thread to receive assistance from Intel experts. Otherwise, the community members will continue to help you here.
Thank you for your engagement!
Fakhrul
0 Compliments
Répondre
