21604 Discussions
Agilex not programming (E tile)
Shubhall
I am currently working Agilex FPGA (AGFB014R24B2E2V). For my design standalone GHRD I am able to program, but when I am adding the JESD example design to it, the following error is coming -
Error (18950): Device has stopped receiving configuration data
Error (18948): Error message received from device: Internal error. (Subcode 0x0001, Info 0x00000000, Location 0x00007C00)
Error (22248): Detected an error during configuration. Refer to the Configuration User guide for details on debug guidelines. Check the latest Intel Quartus Prime software release for possible fixes.
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Jan 24 14:20:17 2023
Error: Quartus Prime Programmer was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 1945 megabytes
Error: Processing ended: Tue Jan 24 14:20:17 2023
Error: Elapsed time: 00:00:21
Error: System process ID: 22300
Kindly help me in the same regard. The .sof files I am able to generate but the programming is giving error.
Quartus version 22.2 and my VID settings are as follows -
set_global_assignment -name USE_PWRMGT_SCL SDM_IO0
set_global_assignment -name USE_PWRMGT_SDA SDM_IO12
set_global_assignment -name VID_OPERATION_MODE "PMBUS MASTER"
set_global_assignment -name PWRMGT_BUS_SPEED_MODE "400 KHZ"
set_global_assignment -name PWRMGT_SLAVE_DEVICE_TYPE OTHER
set_global_assignment -name PWRMGT_SLAVE_DEVICE0_ADDRESS 4F
set_global_assignment -name PWRMGT_PAGE_COMMAND_ENABLE ON
set_global_assignment -name PWRMGT_VOLTAGE_OUTPUT_FORMAT "LINEAR FORMAT"
set_global_assignment -name PWRMGT_LINEAR_FORMAT_N "-12"
Thank you
Shubhangi
ZH_Intel
Hi Shubhangi,
Thank you for reaching out.
Just to let you know that Intel has received your support request and currently we are confirming the details with our internal team.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
ZulsyafiqH_Intel
ZH_Intel
Hi Shubhangi,
We could not replicate your error on our side and currently I am running some test to replicate it.
I believe there is a similar case ticket reported by you in below link:
Case - Not able to program Agilex FPGA
I would like to clarify with you is the case same issue? duplication of case?
If it is the same, I have provided you some input for you to try from your side.
However, I will paste the same answer here.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi Shubhangi,
Good day.
After further checking it seems like it might be some issue with the VID settings.
Based on your Agilex part number, I believe you are using the Agilex F-Series FPGA devkit Production-2V.
For the VID setting, you are required to input below script/code to avoid Quartus from generating an error due to incomplete SmartVID settings.
Intel® Agilex™ F-Series FPGA Devkit User GuideIntel® Agilex™ F-Series FPGA Devkit User GuideIntel® Agilex™ F-Series FPGA Devkit User Guide
You may change the scripts listed below in you project QSF file.
Please ensure that there are no other similar settings with different values.
6.1. Add SmartVID settings in the QSF file6.1. Add SmartVID settings in the QSF file6.1. Add SmartVID settings in the QSF file
For more information you may refer to below link:
Intel® Agilex™ F-Series FPGA Development Kit User Guide - 6.1. Add SmartVID settings in the QSF file
Please try this step and let me know if error still happen.
Thank you.
ZulsyafiqH_Intel
Shubhall
I am really sorry for replying late.
This error is not same as Case - Not able to program Agilex FPGA.   Both are actually different errors, so the solution mentioned above does not work.
This error I am getting when I chose to assign FMC_GBTCLK_M2C_p0 (AJ14) or FMC_GBTCLK_M2C_p1 (AR16) for the JESD transceiver clock (refclk_xcvr). However, when using FMC_REFCLK0_p (AT13) or FMC_REFCLK1_p (AK13) for JESD transceivers, it gives no programming error. and the board configures successfully.
Kindly help me to understand why I can not use the FMC_GBTCLK_M2C_P pin for refclk_xcvr (transceiver clock).
Please note - This error you can replicate by generating any JESD204B  preset example design for Agilex and assigning FMC_GBTCLK_M2C_p0 (AJ14) or FMC_GBTCLK_M2C_p1 (AR16) for refclk_xcvr pin in the qsf file.
Please let me know if more information required from my side.
Thank you
Shubhangi
ZH_Intel
Hi Shubhangi,
Thank you for your reply.
Apologize for the delayed response as we are having some difficulty with our internal system.
Could you share with us your .qar file?
We are trying to replicate the error from our side.
ZulsyafiqH_Intel
ZH_Intel
Hi Shubhangi,
Good day.
I wish to follow up with you on this Case.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi Shubhangi,
We do not receive any response from you for more than a week to the previous reply that I have provided.
With that, this thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
ZulsyafiqH_Intel
