Hi, I was just wondering how it would be possible to make an all purpose sign extension entity in VHDL. So I created this sign extension entity but it will only work if the input is 6 bits long. If I put in an input that was say 3 bits long. It wouldn't work. Is it possible to build a SEXT that doesn't have limitation on input bits?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity SEXT5_0 is
port ( data_in : in std_logic_vector(5 downto 0);
data_out : out std_logic_vector(15 downto 0));
end SEXT5_0;
architecture behavioral of SEXT5_0 is
begin
process (data_in)
begin
data_out(5 downto 0) <= data_in;
data_out(15 downto 6) <= (15 downto 6 => data_in(5));
end process;
end behavioral;
Side question how can I assign multiple signals the same input for example I want to do something like this. Is there a legal syntax or would I have to individually set each signal? R1, R2, R3 < = x"0000"
In addition to the ports, you should add two generics on your entity, and use those to define the sizes of your input and output vectors.
As for your second question, you need to assign individually each signal. Or if your signals are in an array, you can assign each one of them with the same value using the (others => xxx) syntax.- Mark as New
But why not use the inbuilt function "resize" ??? just a single line of code
