I am using an Altera Cyclone V SoC FPGA Development Kit, running a linux-socfpga-4.1.22-ltsi-rt kernel configured (DTB) using the socfpga_cyclone5_socdk.dtsi
Within the (inherited) socfpga.dtsi I observe the following configuration for the GPIO Bank 0-2: gpio0: gpio@ff708000 { # address-cells = <1>; # size-cells = <0>; compatible = "snps,dw-apb-gpio"; reg = <0xff708000 0x1000>; clocks = <&l4_mp_clk>; status = "disabled"; porta: gpio-controller@0 { compatible = "snps,dw-apb-gpio-port"; gpio-controller; # gpio-cells = <2>; snps,nr-gpios = <29>; reg = <0>; interrupt-controller; # interrupt-cells = <2>; interrupts = <0 164 4>; }; }; gpio1: gpio@ff709000 {[/B][/B] # address-cells = <1>;[/B][/B] # size-cells = <0>;[/B][/B] compatible = "snps,dw-apb-gpio";[/B][/B] reg = <0xff709000 0x1000>;[/B][/B] clocks = <&l4_mp_clk>;[/B][/B] status = "disabled";[/B][/B] portb: gpio-controller@0 {[/B][/B] compatible = "snps,dw-apb-gpio-port";[/B][/B] gpio-controller;[/B][/B] # gpio-cells = <2>;[/B][/B] snps,nr-gpios = <29>;[/B][/B] reg = <0>;[/B][/B] interrupt-controller;[/B][/B] # interrupt-cells = <2>;[/B][/B] interrupts = <0 165 4>;[/B][/B] };[/B][/B] };[/B][/B] gpio2: gpio@ff70a000 {[/B][/B] # address-cells = <1>;[/B][/B] # size-cells = <0>;[/B][/B] compatible = "snps,dw-apb-gpio";[/B][/B] reg = <0xff70a000 0x1000>;[/B][/B] clocks = <&l4_mp_clk>;[/B][/B] status = "disabled";[/B][/B] [/B][/B] portc: gpio-controller@0 {[/B][/B] compatible = "snps,dw-apb-gpio-port";[/B][/B] gpio-controller;[/B][/B] # gpio-cells = <2>;[/B][/B] snps,nr-gpios = <27>;[/B][/B] reg = <0>;[/B][/B] interrupt-controller;[/B][/B] # interrupt-cells = <2>;[/B][/B] interrupts = <0 166 4>;[/B][/B] };[/B][/B] };[/B][/B] I then observe this being resolved (runtime, on the board) as: # ls -l /sys/class/gpio[/B][/B] total 0[/B][/B] --w------- 1 root root 4096 jan 1 00:21 export[/B][/B] lrwxrwxrwx 1 root root 0 jan 1 00:21 gpiochip427 -> ../../devices/platform/soc/ff70a000.gpio/gpio/gpiochip427[/B][/B][/B][/B] lrwxrwxrwx 1 root root 0 jan 1 00:21 gpiochip454 -> ../../devices/platform/soc/ff709000.gpio/gpio/gpiochip454[/B][/B][/B][/B] lrwxrwxrwx 1 root root 0 jan 1 00:21 gpiochip483 -> ../../devices/platform/soc/ff708000.gpio/gpio/gpiochip483[/B][/B][/B][/B] --w------- 1 root root 4096 jan 1 00:21 unexport[/B][/B] [/B][/B]I understand that the numbers 427, 454, 483 are the first GPIO Number of the various GPIO Banks, such that e.g. GPIO Bank# 1 represents GPIO Numbers 454 --> (454 + 28). However, it is not obvious to me *where* these magic numbers (i.e. 427, 454, 483) come from. Can someone explain? Thanks.
