Programmable Devices
21615 Discussions
Altera DE1 8-bit Flash ROM as 16-bits?
Hi. My Altera DE1 board has a model 04 Flash ROM which apparently (according to the datasheet) lets me use it as 16-bits instead of 8-bits.
However, when I go to use the Altera DE1 user manual to find the pin outs, all I get are:
  • FLASH Address
  • FLASH Data
  • FLASH Output Enable
  • FLASH Reset
  • FLASH Write Enable
Where are the pins for# BYTE and CE, and the rest of the data pins that make up the 16-bit data pins?
Overall, I just want to be able to use this Flash ROM as 16-bits.
Unfortunately, the board has only implemented an 8-bit interface to the flash, so you're stuck with an 8-bit interface.
Cheers,
Dave
o_O
Well that's unfair.
