Hi. My Altera DE1 board has a model 04 Flash ROM which apparently (according to the datasheet) lets me use it as 16-bits instead of 8-bits.
However, when I go to use the Altera DE1 user manual to find the pin outs, all I get are:- FLASH Address
- FLASH Data
- FLASH Output Enable
- FLASH Reset
- FLASH Write Enable
Unfortunately, the board has only implemented an 8-bit interface to the flash, so you're stuck with an 8-bit interface.
Cheers, Dave- Mark as New
o_O
Well that's unfair.
