21611 Discussions
Altera On-Chip Flash IP Core
I've included Altera On-Chip Flash IP Core in my project. The core created a component
component flash_update is port ( clock : in std_logic := 'X'; -- clk avmm_csr_addr : in std_logic := 'X'; -- address avmm_csr_read : in std_logic := 'X'; -- read avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata avmm_csr_write : in std_logic := 'X'; -- write avmm_csr_readdata : out std_logic_vector(31 downto 0); -- readdata avmm_data_addr : in std_logic_vector(18 downto 0) := (others => 'X'); -- address avmm_data_read : in std_logic := 'X'; -- read avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata avmm_data_write : in std_logic := 'X'; -- write avmm_data_readdata : out std_logic_vector(31 downto 0); -- readdata avmm_data_waitrequest : out std_logic; -- waitrequest avmm_data_readdatavalid : out std_logic; -- readdatavalid avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => 'X'); -- burstcount reset_n : in std_logic := 'X' -- reset_n ); end component flash_update; u0 : component flash_update port map ( clock => CONNECTED_TO_clock, -- clk.clk avmm_csr_addr => CONNECTED_TO_avmm_csr_addr, -- csr.address avmm_csr_read => CONNECTED_TO_avmm_csr_read, -- .read avmm_csr_writedata => CONNECTED_TO_avmm_csr_writedata, -- .writedata avmm_csr_write => CONNECTED_TO_avmm_csr_write, -- .write avmm_csr_readdata => CONNECTED_TO_avmm_csr_readdata, -- .readdata avmm_data_addr => CONNECTED_TO_avmm_data_addr, -- data.address avmm_data_read => CONNECTED_TO_avmm_data_read, -- .read avmm_data_writedata => CONNECTED_TO_avmm_data_writedata, -- .writedata avmm_data_write => CONNECTED_TO_avmm_data_write, -- .write avmm_data_readdata => CONNECTED_TO_avmm_data_readdata, -- .readdata avmm_data_waitrequest => CONNECTED_TO_avmm_data_waitrequest, -- .waitrequest avmm_data_readdatavalid => CONNECTED_TO_avmm_data_readdatavalid, -- .readdatavalid avmm_data_burstcount => CONNECTED_TO_avmm_data_burstcount, -- .burstcount reset_n => CONNECTED_TO_reset_n -- nreset.reset_n );
How should I use it to program CFM on MAX10? I need some example.
I included in my project Flash IP. Compiled and opened qip file. The file imported in my project some files.
flash/flash/synthesis/flash_update.qip flash/flash/synthesis/flash_update.vhd flash/flash/synthesis/submodules/altera_onchip_flash_util.v flash/flash/synthesis/submodules/altera_onchip_flash.v flash/flash/synthesis/submodules/altera_onchip_flash_avmm_data_controller.v flash/flash/synthesis/submodules/altera_onchip_flash_avmm_csr_controller.v flash/flash/synthesis/submodules/altera_onchip_flash.sdc flash/flash/synthesis/submodules/rtl/altera_onchip_flash_block.v
I created my file and included a component from flash_update.vhd. Everything compiles OK. But when I include my component in the top entity I get the following error
Error (14740): Configuration mode on atom "bootloader:U_BOOTLOADER|flash_update:U_FLASH_UPDATE|altera_onchip_flash:onchip_flash_0|altera_onchip_flash_block:altera_onchip_flash_block|ufm_block" does not match the project setting. Update and regenerate the Qsys system to match the project setting.
Well...To compile successfully the Qsys and the project should be configured as Single Compressed Imaged. I don't know how it would impact the project. Have to try.
