21607 Discussions
Altera msgdma busy doesn't complete operation
Description of IP core enabled,
standard descriptor 128bit
no response port
After initiating transfer by writing descriptor control bit
1) MSGDMA been software reset
2) Read CSR status value - 0x10 (FIFO empty)
3) csr control register value - 0x10 (Interrupt enable)
4) slave descriptor Control set to - 80ff6000 (Go Bit | Transfer complete IRQ + bits16-23enabled)
After transfer starts
csr status value changes from 0x10 to 0x11 saying it is busy however transfer doesn't complete and even
csr read fill level - 0x0
csr response fill level - 0x0
Destination and source address atleast 8bytes (double word) aligned
Copy size is also is around 0x60 which is also aligned size.
Please suggest what I am doing wrong or what else to try out for successful DMA transmission.
What is the maximum rate msgdma can operate, can it function at 200MhZ or is there any limitation on clock rate ?
