Dear,
I have a procedure (Sort) that read two numbers in each cycle. and return the max and the min. I am reading two numbers from mif file , the problem is that I want to write back the result returned from the PROCEDURE to the same location of the memory that I had read from. I expected it to be in the next cycle but the memory is not able to be inferred " can't infer memory for variable 'ram1' with attribute '"M4K"'. I listed the code below as reference. Many thanks. ARCHITECTURE behave OF min_max IS TYPE MEM IS ARRAY(0 TO 15) OF signed(9 DOWNTO 0); signal ram1:MEM; ATTRIBUTE ram_init_file: STRING; ATTRIBUTE ram_init_file OF ram1: SIGNAL IS "bits.mif"; ATTRIBUTE ramstyle: STRING; ATTRIBUTE ramstyle OF ram1: SIGNAL IS "M4K"; SIGNAL reg1sig,reg2sig,dataodd,dataeven,minsig,maxsig: signed(9 downto 0); BEGIN PROCESS (clock) variable kk:integer range 0 to 7:=0; BEGIN IF rising_edge(clock) THEN dataodd <= ram1(2*kk+1); dataeven<=ram1(2*kk); reg1sig<=dataodd; reg2sig<=dataeven; Sort(Reg1sig,reg2sig,maxsig,minsig); -- THE PROCEDURETAKES TWO NUMBERS AND RETURN TWO , IT WORKS WELL WITHOUT WRITING TO RAM1 ram1(2*kk+1) <= maxsig; ram1(2*kk)<= minsig; kk:=kk+1; END IF; OUT<=maxsig; END PROCESS;Link Copied
You can only ever read/write 1 value from a ram in a single clock cycle, not two. Your code reads from 2 locations in a single clock, not possible. You may need to build a ram that stores both values in parrallel if you want to do this.
The ram has two ports, I succeeded in reading two values together , but I couldn't write on these location when I added
ram1(2*kk+1) <= maxsig; ram1(2*kk)<= minsig- Mark as New
--- Quote Start --- The ram has two ports, I succeeded in reading two values together , but I couldn't write on these location when I added ram1(2*kk+1) <= maxsig; ram1(2*kk)<= minsig --- Quote End --- Is that the standard template for dual port ram? I never use inference so can't answer you but I have this diversion: if you are checking on data stored in mif, why not pre-compute in software to get your mif ready for max/min
The Quartus created the dual port when you have two reads. The mif data is an example, I need a real time implementation of course.
Dual ports means each port can do either write OR read on each port in clock cycle, not both.
See coding style guidelines here:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts-qpp-5v1.pdf Section 4 (Page 100) Memory is section 4.4- Mark as New
I will read it and check my code. Thanks a lot.
--- Quote Start --- Dual ports means each port can do either write OR read on each port in clock cycle, not both. --- Quote End --- I added another process, ShowResults:Process(Clock,show) variable i:integer range 0 to 7:=0; begin IF rising_edge(clock) and show='1' THEN D<=ram1(2*i); S<=ram1(2*i+1); i:=i+1; end if; end process; acmain<='0' when Z=16 else '1'; --Z is a counter to read 16 elements and then stop activating the first process.acmain is in sensitivity list of first process I listed in first post. show<='1' when acmain='0' else '0'; So, I activate it when I deactivate the first process , So I can either read or write. However Still unable to infer to memory. What is the best solution for that
This is because you're still reading or writing 2 locations at the same time - the ram1(2*i) and (2*i+1). You can only read/write 1 location at the time.
The weird thing is that I am using dual port , in reading these two locations, it . I am using now different memory for each operations , but the number of logic element is so large . Thank you for your reply brother.
You really need to study the document I provided. If your code doesnt match the template, then a ram will not be infered.
I did and I am still reviewing it. Thank you very much for your continuous help and notes.
