21611 Discussions
Another character LCD question
I am using the Cyclone Edition dev kit and I've built a basic Nios II system, and loaded the "count_binary" example program using the Eclipse for Nios II software.
If I set stdout to the LCD then it displays the countdown, but I didn't think that this was necessary. Without this setting the LCD just stays blank.
In count_binary.h there is this section that defines LCD-PRINTF:
#ifndef LCD_DISPLAY_NAME /* Some hardware is not present because of system or because of simulation */# define LCD_CLOSE(x) /* Do Nothing */# define LCD_OPEN() NULL# define LCD_PRINTF(lcd, args...) fprintf(lcd, args) # else /* With hardware devices present, use these definitions */# define LCD_CLOSE(x) fclose((x))# define LCD_OPEN() fopen("/dev/lcd_display", "w")# define LCD_PRINTF fprintf # endifIn SOPC builder my LCD device is named "lcd", so I'm not sure what the problem is here.
There were a couple of naming mismatches that caused this problem:
1. count_binary.c was checking if LCD_DISPLAY_NAME had been defined, but system.h used LCD_NAME.
2. count_binary.h looked for /dev/lcd_display, but my device was actually at /dev/lcd.
I hope this will be useful to someone in the future. The program worked properly after I changed these two things and set stdout back to jtag_uart.
