21611 Discussions
Are there any one-time user-programmable fuses in Arria 10, similar to the bits that used to be available via the ALTOTP atom on older devices (or the EFUSE bits on Xilinx devices)? Thanks
MAdel
Nooraini_Y_Intel
Hi MAdel,
The ALTOTP IP is only supported for ASIC (Hardcopy devices). The OTP fuse in Arria 10 device has a different purpose from the ALTOTP IP in ASIC (Hardcopy devices). The OTP fuses main function in Arria 10 device is for design security purpose and not to program unique ID/code purpose. You can refer to AN566 application note regarding on the design security purpose for FPGA device that provide the OTP type key option (non-volatile key) or re-programmable type key (volatile key).
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an556.pdf
You can read the Arria 10 device handbook to understand the what are the features being offered in Arria 10 family devices:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_handbook.pdf
Nooraini
