Programmable Devices
21615 Discussions
Are these Verilog statements synthesized as parallel HW?
I have 32 different 32 bit- registers where I need to add the numbers of ones in each of them in parallel, to simplify :
begin
A = R1[0] + R1[1] + R1[2] ....... + R1[31];
B = R2[0] + R2[1] + R2[2] ....... + R2[31];
C = R3[0] + R3[1] + R3[2] ....... + R3[31];
D = R4[0] + R4[1] + R4[2] ....... + R4[31];
end
Is the following code synthesized as parallel adders in HW or not? If not, how can I do that, fork/join statements are not supported in Quartus II
VERILOG code is always synthesized parallel, as long as you don't explicitely implement sequential state machines. You may find it more comfortable, to write the adder as an iteration loop, but it will be still synthesized parallel.
Thanks for your prompt reply :)
