Hi everyone,
Can arithmetic operators(such as '+','-',etc.) only be used within process statement? If yes, why?Thanks.Link Copied
No, operators can be used outside process. Then result will not be registered as it is when you use the operators within process.
you can use them in functions and procedures too.
basically, anything in the architecture is a process, just if its placed outside an explicit process it is an implicit process sensitive to all the signals on the RHS: a <= b * c; is the same as: process(b, c) begin a <= b * c; end process;
