Array Problem
Hi again,
When i compile the following code it eats all my logic.
I'm pretty sure its a problem with the use of arrays.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity VERTICAL_COUNTER is port ( RESETn : in std_logic; CLK100MHz : in std_logic; COUNTER_ABLE : in std_logic := '0'; CAM_FRAME_VALID : in std_logic := '0'; CAM_LINE_VALID : in std_logic := '0'; CAM_DATA_VALID : in std_logic := '0'; CAM_DATA : in std_logic_vector (7 downto 0) ; READ_FROM_ARRAY : in std_logic := '0'; WRITE_ENABLE : out std_logic := '0'; DATA_VALID : out std_logic := '0'; DATA_OUT : out std_logic_vector (7 downto 0); -- ARRAY_ERROR : out std_logic := '0'; -- COLUMN_NUMBER : out std_logic_vector (10 downto 0); OUTPUT_amp_max : out std_logic_vector (7 downto 0); OUTPUT_amp_06 : out std_logic_vector (7 downto 0); OUTPUT_amp_n1_greater : out std_logic := '0'; OUTPUT_position : out std_logic_vector (7 downto 0) ); end entity; architecture rtl of VERTICAL_COUNTER is type array_type_8bit is array (0 to 1279) of std_logic_vector (7 downto 0); type array_type_1bit is array (0 to 1279) of std_logic; signal array_amp_max , array_amp_06 , array_position : array_type_8bit ; --:= (others => (others => '0')); signal array_amp_n1_greater : array_type_1bit ; --:= (others => '0'); signal counter : integer range 0 to 1280 := 0; signal line_counter : integer range 0 to 255 := 0; signal read_counter : integer range 0 to 1280 := 0; signal counter_max : integer range 0 to 2047 := 0; signal data_loaded : std_logic := '0'; signal send_data : std_logic := '0'; signal buff_line_valid : std_logic := '0'; signal out_amp_max : std_logic_vector (7 downto 0) := (others => '0'); signal out_amp_06 : std_logic_vector (7 downto 0) := (others => '0'); signal out_greather : std_logic := '0'; signal out_position : std_logic_vector (7 downto 0) := (others => '0'); begin prog_adr : process (CLK100MHz) begin if rising_edge (CLK100MHz) then data_loaded <= '0'; counter <= counter; read_counter <= read_counter; WRITE_ENABLE <= '0'; DATA_VALID <= '0'; DATA_OUT <= (OTHERS => '0'); if COUNTER_ABLE = '0' then -- reset condition send_data <= '0'; counter <= 0; read_counter <= 0; else -- COUNTER_ABLE = '1' if CAM_FRAME_VALID = '1' then -- or data_loaded = '1' then read_counter <= 0; send_data <= '1'; buff_line_valid <= CAM_LINE_VALID; if buff_line_valid = '1' and CAM_LINE_VALID = '0' then line_counter <= line_counter + 1; counter_max <= counter; counter <= 0; end if; if CAM_DATA_VALID = '1' then -- and data_loaded = '0' then data_loaded <= '1'; if CAM_DATA >= array_amp_max(counter) then out_amp_max <= CAM_DATA; out_amp_06 <= std_logic_vector( to_unsigned( to_integer( unsigned( CAM_DATA )) * 16 + to_integer( unsigned( CAM_DATA )) * 2 + to_integer( unsigned( CAM_DATA )) + 16 , 13))(12 downto 5) ; else out_amp_max <= array_amp_max(counter); out_amp_06 <= array_amp_06 (counter); end if; if CAM_DATA > array_amp_06 (counter) then out_greather <= '1'; else out_greather <= '0'; end if; if CAM_DATA <= array_amp_06 (counter) and array_amp_n1_greater(counter) = '1' then out_position <= std_logic_vector (to_unsigned(line_counter,8)); else out_position <= array_position(counter); end if; else if data_loaded = '1' then counter <= counter + 1; array_amp_max(counter) <= out_amp_max; array_amp_06(counter) <= out_amp_06; array_amp_n1_greater(counter) <= out_greather; array_position(counter) <= out_position; end if; end if; else counter <= 0; line_counter <= 0; if send_data = '1' then WRITE_ENABLE <= '1'; if read_counter >= counter_max then send_data <= '0'; elsif READ_FROM_ARRAY = '1' then read_counter <= read_counter + 1; DATA_VALID <= '1'; DATA_OUT <= array_position(read_counter); array_amp_max(read_counter) <= (others => '0'); end if; end if; end if; end if; end if; end process; end rtl;
Explanation:
When frame valid (image is read in) i'm doing some actions.
1) searching the max amplitude in every column.
2) calculating MAX value * 0,6 (see an other topic i started)
3) Searching the calculated value in the column and
storing the position (line number).
When frame is not valid, i can read out the array (RAM)
My last problem with arrays was when i made the whole array empty
so it didn't used RAM but logic.
Q: Why is it making logic this time ? Anyone has a better way to write
this code? (Less resources and still readable, cauze i'm still learning)
I think the compiler has a problem to synthesize a Ram because of following code:
if CAM_DATA >= array_amp_max(counter) then . . . out_amp_max <= array_amp_max(counter); . . .
In these lines you are asking from the MLAB RAM to deliver a result in one clock cycle, which it can't. The Read Address is first registered before being applied to the RAM-cells, which delays the result by one clock cycle. So the compiler uses logic cells to build that section, requiring 1280 * 8 LEs per array. I suggest you read about the internal RAM blocks.
I never have the compiler infer a RAMs for me, I always either use the MegaWizard, but most often I instantiate a RAM component directly (peeking into what the MegaWizard generates helps to understand what generics to apply).
Thx! I'll should do some reading :)
With some syntax issues getting figured out, i have it working like a
charm!!( used dual ram template )
Thx josby and till my next question.
