I design a board with altera Arria 10 FPGA "10AX115N3F40I2SG" i can successfully program Fpga with altera bus blaster 2. Now I want to program board by using bus blaster V3, i tried a lot but failed to program it. Urjtag can not recognize the bsdl file. I download the bsdl file from altera website. I wonder did i downloaded correct file, the file i downloaded was "10AX115NF40". Any help can be appreciated to pull me out from this problem thanks. I attached the urjtag command line image as well.
