Programmable Devices
21618 Discussions
Arria 10 GX otsu not working
Chinmay02
I am facing problem with loading bitstream onto my Arria 10 GX PAC whereas it is working with the latest opae 1.2.1 it shows fpgainfo fpga but the problem is that it showing the fw version as unavailable also the bitstream version is saying 1.1.3, i try fpgasupdate, fpgaotsu, super-rsu none of them are working, mostly showing me error called secure PAC not found.
I read through a thread which talked about similar issue and the solution was mentioned to update the BMC and the firmware bitstream through usb blaster 2, currently I have it but i am unable to figure out which bitstream i am supposed to flash and how
JohnT_Intel
You will need to upgrade it to 1.2 before going to 1.2.1. Please refer to https://www.intel.com/content/www/us/en/docs/programmable/683633/1-2-1/selecting-the-correct-update-method.html.
Chinmay02
Sorry i am new to upgrading acceleration stacks so i just want to confirm that i need to install the 1.2 stack version (its the only one i can see in the archive) and then upgrade it to 1.2 and then install the 1.2.1 acceleration stack
Thank you
JohnT_Intel
Yes, you are correct. You will need to move to 1.2 and only 1.2.1
Chinmay02
hey,
so as i was told i tried to intall the 1.2 acceleration stack from the archive but the download is not available for this version i am able to download the 1.0 version but not the 1.2
https://www.intel.com/content/www/us/en/software-kit/665889/intel-pac-with-intel-arria-10-gx-fpga-aceleration-stack-version-1-2.html
this is the link i am trying to access and i am unable to download
JohnT_Intel
I am able to observed the same thing. I am working internally to see if we are able to recover the package file.
JohnT_Intel
We will be trying to recover the installation package for you to download. Please check back again by end of October if you are still facing issue.
