21615 Discussions
Arria 10 net lengths
Ezmartin
I do not see the 10AS048EF29 in the net lenghts download from the following intel link:
https://www.intel.com/content/www/us/en/docs/programmable/683073/current/net-length-reports.html
Does one exist or who do I need to contact about getting these package pin delays.
AminT_Intel
That will be under Arria 10 from the link you have shared.
Thank you.
Ezmartin
Thanks for your response.  Although the device that I am looking for 10AS048EF29 does not exist in the list of netlength worksheets from that link.  Below is a snapshot of the 10AS devices within that link.
Please advise if the 10AX048EF29 and the 10AS048EF29 use the same pin package netlengths.
Thank you
AminT_Intel
Thank you for pointing that out. I will need to check with my team to see if we help you with this issue.
Thank you,
Ezmartin
Just wanted to follow up to see if you or your team has found a solution to this issue.
Please email me your response or the pin package delay for the device I'm in need of.
david.martinez@coloradoengineering.com
Thank you,
DM
AminT_Intel
Attached is the file you've requested.
Thank you
Ezmartin
AminT_Intel
 I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Ezmartin
I have a follow up question regarding this topic.  A fellow engineer when looking at the pin package netlengths from the file you sent me back on 3/14/22 (10AS048EF29_netlength.xlsx) identified that the worksheet name represents a different device ( 10SX048EF29 ).
Would you please verify if the supplied spreadsheet and pin delays are for the Arria10 device requested?
Kind Regards,
DM
