- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I am using the JS28F256M29EWH NOR Flash with only using 8-bit data and 25-bit address Parallel Flash in FPP mode. In my case, our flash 8-bits flash data pins are directly connected with fpga_config_data's 8-bit pins. Mostly, these pins I recognize are connected with CPLD, and another set of CPLD pins is connected with fpga_config_data for configuration.
I am following the instructions from ug_pfl.pdf to convert our .SOF to .POF. For NOR Flash programming, I am using the PFL Mega core IP in Mode "only Flash programming" from Arria II FPGA I check read back by using option bits
Now, I am attempting to configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II.
Please find the attached file.
The issue is that the code doesn't work. I am checking fpga_dclk and fpga_nSTATUS pins using an oscilloscope, but no activity is showing. This implies that there might be a problem with RESET_n and MAX_EN as given in the VHDL Codes.
Also, I have defined unused pins as "As Output Ground"
Please help me identify where I am making a mistake.
Nome
- Marcas:
- Arria ii GX
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you for contacting Intel community.
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II"? What is the reason on using Config_Control_Codes from Intel Altera Stratix II for Arria ii?
What Quartus version do you used?
Any error shows?
Aiman
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you for your reply.
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II?
I am not utilizing PFL (parallel flash loader) due to the limited LE (logic element) blocks available, as the EPM240T100I5 CPLD has only 240 blocks. This restriction prevents the use of a higher-density CPLD.
We need to allocate more space for various functionalities, aside from FPGA configuration. This is why we are using the official config_control_codes from Stratix, as indicated in the attached QAR file in my initial post.
All specific pin requirements, such as fpga_addr, fpga_nSTATUS, fpga_dclk, and others, have been assigned according to our custom board specifications. However, the issue is that these codes are not working; when testing fpga_dclk from the oscilloscope, it remains low at all times.
Nome
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Is JTAG working fine? (without config control codes)
- Where did you get the Config control codes? Is it from Intel or other source?
- Can you provide us your schematic?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for your Reply
Is JTAG working fine? (without config control codes) Yes Excellent Working i can get CPLD and FPGA in quartus programmer even I can get Flash when I load as per our board pins assignment PFL (prallel flash loader) .sof file into FPGA can easily flash programming .
Where did you get the Config control codes? Is it from Intel or other source? yes From Intel official site
Nome
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Please provide the link to the Config_control code page so we can do the checking.
Aiman
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Any update for this case?
Aiman
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I apologize for the delayed response due to my long vacations.
Please find attached our configuration area schematic pdf .
Could you please assist me in identifying any errors, such as incorrect addresses entities?
I'm uncertain about the correctness of the configuration. also suggest us if i will consider PFL prallel flash loader
Nome
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
