21400 Discussions
Arria V Avalon-MM Hard IP for PCIe PLL lock
KSMark
Is there a pin from the Avalon-MM Arria V Hard IP for PCI Experess that I can monitor the serdes_pll_locked signal or someother downstream signal I can infer the pll lock state.  I am getting an occasional reset from the PCIe core(during and ESD event).  I have mostly ruled out the reset going into the part and would like to determine if my clock is remaining stable.
I am using quartus version 18.1.0 and the part is an 5AGXMB7G4F35I5.
Farabi
You can create another pin connected to the serder_pll_locked or coreclkout_hip clock signal with platform designer to monitor the pll locked signal.
regards,
Farabi
Farabi
attached is userguide
(Virus scan in progress ...)
Farabi
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
