21602 Discussions
Arria V GZ Transceiver Native PHY reference design using the 10G PCS
lcoon1981
Is there any reference design available for AV GZ using the Transceiver Native PHY with 10G PCS to achieve 12.5 Gbps performance? I will be using Arria V 5AGZME7H2F35I3 for the project.
Thank you!
Kshitij_Intel
You must be able to generate the example design using IP Parameter Editor for the required configuration.
FYR Refer to V-Series Transceiver PHY IP Core User Guide(attached).
Thank you
Kshitij Goel
lcoon1981
Hi Goel,
Not all IP core can generate the example design using IP Parameter Editor. I am looking for Arria V GZ Transceiver Native PHY IP Core, and the IP Parameter Editor cannot generate example design. Do you have example design that can share?
Kshitij_Intel
lcoon1981
Thank you!
